IC1795 Fish Nebula *** Reprocessed
Started by ApophisAstros, May 08, 2018, 12:49:51
Last nights offering.
26 Lights x 300s
50 x Flats
Imaging telescope or lens:SkyWatcher 120ED Imaging System for Canon DSLR Cameras
Imaging camera:Canon 1000D modified
Focal reducer:Skywatcher 0.85x Focal Reducer/Corrector for Evostar-120ED
Software:DeepSkyStacker x64 by Luc Coiffier, Tony Cook, David C. Partridge Deepsky Stacker 4.1 64bit,
Astro Photography Tool,ADOBE PHOTOSHOP CC
Accessory:QHYCCD PoleMaster
Resolution: 3906x2602
Dates: May 7, 2018
Frames: 26x300"
Integration: 2.2 hours
Avg. Moon age: 21.62 days
Avg. Moon phase: 55.60%
Astrometry.net job: 2050380
RA center: 36.619 degrees
DEC center: 61.850 degrees
Pixel scale: 1.492 arcsec/pixel
Orientation: 79.095 degrees
Field radius: 0.973 degrees
Looks pretty good, but rather dark including the stars, what have you done in the processing to cause this?
This target is catching on! Looking good.
The reprocessed version is looking much better Roger.
Well done.
thanks all,
I am slowly learning a little more on processing each time,
