Hitecastro Mount Hub Pro
Started by Fay, Mar 20, 2018, 09:16:58
I am selling the above, as have bought another one.
this is in perfect working order, no problems. Eliminates having loads of cables going from equipment to the computer by just having one.
Most equipment can plug into it
8 individually selectable and controllable relay driven outputs to power all of your equipment. (plus three constant (always on) outlets.)
A 4 channel dew controller with individually selectable outputs.
A stepper motor focus controller compatible with many of todays most popular focusers (e.g. Moonlite, Robofocus)
PC software which allows all of the above to be controlled from the users PC (Windows XP, Vista) Windows 7 currently under test.
Manual (Non PC based control of the Dew Controller)
Optional Manual 'Hand Controller' for focus operations
An ASCOM compliant driver to operate with your favourite third party ASCOM compliant application. (e.g. Maxim DL, CCD Soft etc)
USB Interface (standard printer type usb cable required
Can deliver up to 15Amps of power to your equipment (via an appropriate power supply)
As one power cable leads from your power supply to the 'Mount Hub Pro' and one USB cable runs from the controlling PC to the MHP, there is less chance of tripping or getting tangled in lots of cables in the dark. Power outlets to your equipment are then provided so cables no longer dangle where they can cause problems.
£190
Does it work with Windows 10 Fay.
