Author Topic: Moon 28-Dec-2017  (Read 481 times)
Moon 28-Dec-2017
« on: Dec 30, 2017, 15:33:41 »
The moon taken with the Sony A7S on the Celestron C11 with a (new!) Starizona large format corrector.
100 frames at 1/250sec stacked in AutoStakkert!2 using Bayer Drizzle then deconvolved with a Gaussian point spread function in my own software.
Make sure you see the wonderful detail in the 100% scale version here: http://www.markshelley.co.uk/Astronomy/2017/moon20171228_100.png
There are a few deconvolution artifacts but not many :)
Here's the colour saturated version, showing a bit of moon geology:
Larger version (50% scale): http://www.markshelley.co.uk/Astronomy/2017/moon20171228_50_colour_enhanced.png
I'd like to do the coloured moon again, when the moon is full.
« Last Edit: Dec 30, 2017, 15:39:53 by MarkS »
    • Carole's images
Re: Moon 28-Dec-2017
« Reply #1 on: Dec 30, 2017, 17:17:17 »
Speechless.
Absolutely amazing Mark.
  • Mr October
  • Galaxy Class
« Reply #2 on: Dec 30, 2017, 19:48:26 »
Just had a look close up on my monitor. Amazing detail and quality. Everytime I try the Moon I get a bright ring artifact at the curved edge, how did you avoid that?
  • Non-OAS
  • Galaxy Class
    • JP Astro Images
« Reply #3 on: Dec 30, 2017, 21:14:17 »
Nice Mark. John
« Reply #4 on: Dec 31, 2017, 08:20:22 »
Quote from: The Thing
I did nothing special to avoid a bright ring - I suppose it depends on its cause.
One annoying thing is that AS!2 ran out of memory when processing an AVI of the full frame image.  So I had to use PIPP to produce 6 different cropped versions of the AVI.  The final results had to be reassembled as a mosaic.  I wasn't happy because it turned a straightforward task into something very time consuming  :(
« Last Edit: Dec 31, 2017, 10:15:27 by MarkS »
  • Nebula Class
« Reply #5 on: Dec 31, 2017, 09:59:27 »
Spectacular Mark
Love the colour Moon.
  • Mr October
  • Galaxy Class
« Reply #6 on: Dec 31, 2017, 12:33:53 »
I like the colour one as well I believe there is an AS3! Beta 64bit which gets round the limitations for big avi's.
« Reply #7 on: Dec 31, 2017, 15:07:57 »
That's probably just what I need.
    • Faysastroimages
« Reply #8 on: Jan 01, 2018, 10:16:20 »
Really lovely Mark. i do like the colour version
  • Non-OAS
  • Galaxy Class
    • JP Astro Images
« Reply #9 on: Jan 01, 2018, 11:49:16 »
Mark just checked this out on my big monitor & detail is amazing - what camera did you use (bit confused) was it your sony of a video camera?  John
« Reply #10 on: Jan 01, 2018, 17:19:29 »
Quote from: JohnP
It was 100 still frames taken with the Sony A7S.  The seeing was the "slow and wavy" type rather than the "fast and jittery" type.
I might give it another try tonight (to get better colouration) with an almost full moon but I suspect the wind will play havoc with the seeing.
  • Non-OAS
  • Galaxy Class
    • JP Astro Images
« Reply #11 on: Jan 01, 2018, 18:07:03 »
Ok thks - this bit confused me as you are talking about AVI's not still frames...
Quote
« Reply #12 on: Jan 01, 2018, 23:56:34 »
Quote from: JohnP
Quote
AS!2 does not accept still frames.  So I had to first turn them into a lossless undebayered AVI file.  I did that using PIPP.
« Reply #13 on: Jan 02, 2018, 06:31:36 »
It works!!
Using PIPP I can create a full size AVI file from my raw frames and the 64bit AS!3 processes the whole moon in one go.  Tonight I can process my full moon data from last night :)  The seeing was not so good but it should still produce a good colour image of the whole face of the moon.
  • Mr October
  • Galaxy Class
« Reply #14 on: Jan 02, 2018, 11:07:42 »
CNN called it a Wolf Moon for some reason, there won't be a bigger one this year. Hope it comes out ok. Are you using your DCON3 program for the deconvolution? I have a copy somewhere.
Too murky to do any Moon snaps here but it sure was bright last night. Had a good look with my big 20x80 bins that I collimated New Years Eve - what a difference and they were good before :)
