M31 Andromeda - Updated
Started by ApophisAstros, Nov 02, 2017, 23:19:55
I think this becoming one of my favourite targets.
Had another go from the begining without darkening.
Taken 29/10/2017 Worthing.
58 x 300 second subs
20 x flats
10 x darks
20 bias
Processed with the latest Photoshop64bit CC 2018 ,amazing piece of kit.
GradientXterminator and HLVG(Hasta La Vista Green)for green noise.Thanks Carole for heads up on those..
Kit
SkyWatcher 120ED Imaging System for Canon DSLR Cameras
Canon EOS 750D DSLR - Modded for Astro Imaging FOV 1.67 x 1.11 arc mins
Skywatcher EQ6-R PRO Synscan Skywatcher 9x50 Finderscope w/QHY5L-II MONO
Skywatcher 0.85x Focal Reducer/Corrector for Evostar-120ED
Incanus Ltd. Astro Photography Tool,
Luc Coiffier Deep Sky Stacker 3.3.4
QHYCCD PoleMaster
Wow - that's nearly 5 hours of data!
It's looking good but to improve it further you will definitely need to try it from a dark site.
Thanks Mark,
Yes i agree , but not bad given the moon and LP.
Roger, try not to darken the sky too much, your black point is clipped (check the histogram), this is because you have darkened the sky too much.  That also has the result of losing some of the fainter details.
Quote from: Carole
That's good advice.  I never let my background go black.
That's much better Roger, I like it that way up too.
I think its because of the Meridian Flip as light no 45 (which up to this point included bright moon aswell) jumps to no 58 from which they are much better lights, so by the time i went out and realised i had to flip , i must have lost 13 lights,as i didnt change it in PS, i just some slightly different better lights so DSS must place it whichever way the most lights are.
Quote from: Apophis on Nov 05, 2017, 11:15:37
Hi Roger
Nice Andromeda's, I tend to make the background too dark as well, makes the image leap out of the screen but technically not good as you lose detail in the dim bits.
Use the groups functionality in DSS for before and after flip images, put the subs that are the best along with your calibration frames in Main Group, pick the one thats the right way up/best and right click then 'set as reference frame'. If there are different calibration frames for other groups stick them in the appropriate group. Sky differences are much better dealt with using the Groups as are different nights (when you may have to have different flats and darks).
After the first run through in DSS I deselect the calibration frames then add the Master (either TIF or FITS depending what you specified for intermediate files) ones DSS has created to the file list. Save reprocessing them. Also you can select an area on your reference frame and just process that while you tweak settings. Much much faster. Don't forget to save the file list!
HTH
Duncan
Thanks everyone, good advise from all as usual.
