Author Topic: Hotmail to Outlook  (Read 761 times)
    • Carole's images
Hotmail to Outlook
« on: Sep 20, 2016, 10:18:37 »
Any-one use Hotmail.
I seem to have had my hotmail converted to Outlook and it's awful, I hate it, its slow to respond to any command, and the flagged items don't show clearly.
This is not an upgrade, it's a downgrade, upgrades should be an improvement, why must they always keep tinkering with things, if it's not broke no need to fix it.
I guess I am stuck with it, unless any-one knows better?
Apophis
  • Star Class
  • Skywatcher
Re: Hotmail to Outlook
« Reply #1 on: Sep 20, 2016, 10:23:47 »
had GoogleMail for as long as i can remember , always fast and never a problem.
Look and ye shall find
    • Carole's images
« Reply #2 on: Sep 20, 2016, 10:28:38 »
I have googlemail (I used it for back up in the past and I use the google calendar which I can sync to my smartphone), but I don't like the way that works for E Mail.  Was always missing new mail because they rolled it onto the end of a previous conversation.  Had the same problem with Virgin webmail (who are my ISP).  So went over to Hotmail as I preferred the way it worked, also can access from anywhere.
Don't really want to have to change it again, I guess I'll just have to get used to it.
  • Observing Consultant
    • Electronicle
« Reply #3 on: Sep 20, 2016, 12:57:57 »
That is conversation view. Simply disable it for normal view.
    • Carole's images
« Reply #4 on: Sep 20, 2016, 15:52:20 »
Quote
Didn't know you could so that.
Pretty sure you can't with Virgin webmail, I found that totally impossible to cope with.  Folders would disappear, you'd get about 4 or 5 lines of E mails showing and about 5/6 of the page would be blank.
Well I'll persevere with Outlook for the time being as it's a real fag changing E mail addresses.
    • Electronicle
« Reply #5 on: Sep 20, 2016, 16:55:37 »
I presume you are doing everything in a browser window in which case you will be limited. Use an email client such as Thunderbird.
    • Carole's images
« Reply #6 on: Sep 20, 2016, 18:15:00 »
Quote
Yeah, I know it's not strictly Windows, but it's not astronomical, so moved to PC Helpline.
http://forum.orpington-astronomy.org.uk/index.php?topic=10855.0
Sorry, I thought that was where I put it.   :oops:
  • Administrator
« Reply #7 on: Sep 21, 2016, 21:36:57 »
No big deal. I'm also wondering whether to split the thread about the last imaging session to move the practical post-session discussion out of "Behind the Scenes" into "Technical"...
    • Carole's images
« Reply #8 on: Sep 22, 2016, 09:47:24 »
Yes might be a good idea Rick.
    • Carole's images
« Reply #9 on: Sep 22, 2016, 11:11:13 »
Starting to get used to this, but it's still a bit clunky, i.e. you click on something and it takes a while to respond.  Never had this problem with Hotmail.
