Author Topic: ... and again  (Read 1256 times)
doug
  • Observing Officer
  • Cluster Class
... and again
« on: Jun 16, 2016, 10:38:52 »
Another experimental shot with the new camera of Jupiter and Moons, this time at 4000mm zoom. Had the timer on for anti-shake, but still it blurred slightly. Oh well, press on.
  • Observing Consultant
    • Electronicle
Re: ... and again
« Reply #1 on: Jun 16, 2016, 19:07:34 »
If you're not using a tripod then try resting it on a cushion. Even better still, if you have a beanbag or one of those 'hot water bottles' that are filled with grains or beans then use that.
doug
  • Observing Officer
  • Cluster Class
Re: ... and again
« Reply #2 on: Jun 17, 2016, 08:52:47 »
The camera was on the tripod but the extension pole in the centre was too high... it made it "wobbly" The next time I will leave the camera in a much lower position which should stop the wobble. But thanks for the comment.
Doug.
  • Mr October
  • Galaxy Class
    • AstroManche
Re: ... and again
« Reply #3 on: Jun 17, 2016, 12:06:16 »
Good shot Doug! You could do a nifty timelapse with a few shots like that.
With the tripod, also hang a weight from it and it will be much steadier.
¯\_(ツ)_/¯ (Gallic shrug :))
Kenny
  • Cluster Class
Re: ... and again
« Reply #4 on: Jun 17, 2016, 12:15:47 »
Well done catching Jupiter's moons but of course that means Jupiter is over exposed.
