M42 - Horsehead Nebulae - 1st attempt with camera lens
Started by Carole, Jan 24, 2016, 13:48:00
As stated this is my first attempt with a camera lens to get a DS object (I sort of skipped this stage when getting into imaging and went straight for scope imaging).
My first DS image with a camera lens.
Canon 450D & 18 - 200mm zoom lens @ 200mm F5.6 800iso
Mixture of 10 x 5mins, 15 x 180secs and 9 x 30secs for the core
NEQ6 guided
Not a patch on Fay's image, but obviously using different equipment.
Waxing gibbous Moon which gave some gradients, most of which I managed to get rid of.
Stars are a bit squiffy here and there, guess this is another learning curve.  Any thoughts on this?
Then for fun I added Ha data from previously taken images obviously taken with scope and mono camera.
That's a really good attempt.
I'm afraid that squiffy stars are a frequent problem with camera lenses - especially zoom lenses.  You will be much better off using a good quality prime lens i.e. a non-zoom lens.
That's pretty good considering you've used a zoom.  IMHO it's only worth persevering with it if you don't look too closely at the corners.
Thanks Mark and Robert.  So no remedy then for the stars?
QuoteYou will be much better off using a good quality prime lens i.e. a non-zoom lens.
There was about £400 difference in price as I managed to get this lens on Ebay 2nd hand, so I bought it to "give it a go" and see how I get on.  If I decide to "persevere with using a lens", then I'll upgrade later on.
There were just a few widefield targets I wanted to get this being one of them, so didn't want to spend a fortune.
I'm seriously considering the Samyang 135 f/2 which should be usable wide open with your canon.  Samyang do have a bit of a problem with quality control but if you get a good one then it will be superb.
