Help, cant balance my scope!!
Started by JonC, Jun 13, 2015, 07:40:26
JonC
I am using a Vixen Sphinx mount with a rather lightweight SW 130pds, the supplied counterweight is way too much, does anybody have a 2Kg ish counterweight I can try? The CW shaft is 20mm, and I believe the current weight is 5Kg. If anybody wanted to do a straight swap that would be even better, or one they want to sell.
Cheers
Jon
Have you tried sliding the weight further up the shaft?
JonC
Yep tried that. Looked at prices for proper weight and its around £40, 4 x 0.5kg dumbbells are £4 and a bit of fiddling to reduce the collar and add a locking screw.
I have some dumbbell weights you could have if it helps.
