Cartes du Ciel version 2.76
Started by Whitters, Nov 24, 2004, 17:52:00
Hello,
Yes, you read right, a new update for CDC version 2 is available!
This was motivated by the correction of a long lasting bug with
computer using an ATI graphic card.
On the occasion all the other cumulated patch where merged to this new
version.
Only one new function, the capability to access the USNO-B1.0 catalog
from Vizier to draw chart to magnitude 20.
Bug fix :
 Correct a bug to the artificial satellite chart near 0h00 UT.
 Add day time satellite pass.
 Correct drawing of Jupiter GRS position.
 Better printer resolution detection.
 Correct the USNO-A sequence number.
 Error with Deepsky2000 HGSC and SuperTycho.
 Floating point exception when using USNO-A catalog.
 Cannot input data to some numeric field.
 Support old ATI OpenGL drivers.
New function :
 Add online USNO-B1.0 data from Vizier.
 Change default GRS longitude to current value (95d)
A small update package (1.4MB) is available from
http://www.stargazing.net/astropc
There is also some advance to the version 3.0. I hope for a new test
version at the end of the year
Best Regards,
Patrick
