IC443 - Jellyfish nebula
Started by Ivor, Mar 30, 2012, 23:15:00
Ivor
Fancied giving this a go before it disappeared but I only managed a few subs but I'm pleased with what I managed with the limited data. I took a couple of S-II subs (there no O-III I discovered as well) hoping to go back for more but the nights were against me, I'll be going back later in the year to try again.
4 x 10mins HA ST8300M FLT110
Ivor,
That's looking really good even with such a small integration time.
Nice one!
Yes, I'd agree with Mark, that's an excellent start.  There's a bit of coma showing in the corners but not too bad.
Ivor
Thanks for the feedback. I started getting the coma since swapping from the DSLR and I thought it meant I needed to adjust the Reducer/Flattener I've playing around with it but all that happens was the stars went out of focus. Is it caused by the chip size change and is there anything I can do to get around it preprocessing?
Quote from: Ivor
Which scope and reducer are you using.  If the DSLR produced coma free images, is it possible that the reducer to CCD distance is different for the new camera?
Ivor
I'm using the FLT110 and the WO reducer/Flatener IV
http://www.williamoptics.com/accessories/flattener4_features.php
How do you work out the distance required?
Ivor,
You dial in the distance on that one say 60mm and then space from the bottom of it to the film place, at 60mm it has to be 60mm +- 1mm to get round stars.
