M57 5x1800 12nm ha, Atik 314L SW120 0.85 flattener
Started by Fay, May 25, 2011, 18:39:00
I have clipped the black point a bit, but am planning to add LRGB if I can get a life extension
That's looking sharp Fay. More onion ring than smoke ring, if you see what I mean. Very nice. You go ask the vicar nicely for that life extension. This would look smashing in colour.
Blimey Fay 30 minutes subs x 5!!!!
This one is quite a difficult subject in one way or another.
Well done
Fay - That's not too bad - Like you say black is clipped & there is some sort of gradient bottom left but impressed with your 30min subs. I have come to conclusion that it is very tough to do this one justice unless you have the focal length - It is just too damn small...
Yes, hard to process as well. There is a gradient on both sides. Now the bar has been raised on some of these objects, if you are not in a good place, with suitable optical equipment, then it will be a trial to get the most out of the nebula. Just a normal image is not good enough now!!!!
Glad that I did 30 min subs, that  will prepare me for nebulae season, probably will not be able to do it anymore, you know how it goes!!!!
