First small mosaic
Started by Fay, May 25, 2010, 17:41:25
Popped outside last night. What a difference a night makes, could hardly see anything with the x2 Barlow, so took it off & tried my first mosaic.
3x10 x1/500th sec subs (i think), Atik 314L, ha filter, 6" Mak Cass. Captured with Astroart, then stacked separately in Registax. Mosaiced in IMerge. Processed in PSCS.
Not a special image but glad I have had a go. Must get really complicated when taking about 30 subs!!!!!
That's came out really well. I like it.
Very nice Fay. Good joins.
Can you capture a video stream with your Atik? It would be a lot easier to process a lot of 'subs' using Registax if you could.
Well, thanks Mike, Duncan.
No not video, Duncan. It was a trial run
Thanks Mac, nothing special but was a change to do.
PhilB
Very nice, Fay. It's interesting how the scene changes in just a day or so.
Very nice Fay.  Your first mosaic!  I like it a lot and it looks pretty seamless to me.
I've noticed that the bottom looks slightly less sharp than the top - any idea why?
No Mark, I will check it out
Great piece of work Fay.
Good work Fay and the joins are seemless.
Mark, not sure about the bottom looking less sharp. The bottom frame goes a long way up on the one before, nearly to the centre, not where it appears to go
