ED80 flattener test done
Started by Rocket Pooch, Dec 20, 2009, 20:37:13
ok blow up 200% tonight with the flattener
origional image without
full frame with flattener
Chris,
That's looking very good.
Here are the tests I did with the WO Mk2 0.8x flattener - with the spiky stars in the corners:
http://forum.orpington-astronomy.org.uk/index.php?topic=5105
Wonder if it's too late to ask Santa Claus for the Skywatcher flattener?
Not perfect but for what is a relatively inexpensive chunk of glass it does an amazing job on a near APS chip.  It's certain to become one of the must have accessories for the ED80...  I wonder how it would work on some of the WO scopes?
#3
I thought that this 0.85 FR only fits the new DSPRO Black Diamond scopes & the fitting on the gold Skywatcher pro ED80 is not suitable?
(had the colour wrong)
I think a) when I focus better and b) when I use the OAG it will probably improve the image, but I tell you what if you bought one of these and a second hand ED80 £300 would give you a hell of a setup.  Just need to run it through CCD Calc to see how flat the image is, without it was 35% curved.
And this was the top left corner at 200% at 100% the star look pretty tight.  Needless to say I'm happy I get to keep my ED80 :-)
Quote from: Fay on Dec 21, 2009, 09:25:58
I thought that this 0.85 FR only fits the new DSPRO Black Diamond scopes & the fitting on the white Skywatcher pro ED80 is not suitable?
Hi Fay,
These are the same just black with a 1/10 reducer on the focuser, the equinox is the one it does not work with.
Quote from: Space Dog
... when I use the OAG it will probably improve the image
Does your camera have the integrated guiding port?
Presumably you have to attach a guide camera to this?
I'm very interested in how you get on.
I did not get the one with the guide port because the back focus goes up quite a lot, but I'm going to get the TS OAG, this is 9mm long leaving a 10mm spacer required for any t-mount devices, MPCC, SW .85 etc.
