SX problem.............give me strength!!!!!!
Started by Fay, Oct 20, 2009, 14:35:45
QuoteSo mount and camera is OK on one battery, but have laptop on a different one
Hmmm, better check my stuff before DSC then.
I'm running DSLR own battery,but software for this on the laptop.
Laptop, Mount and SC3 (as a guide cam) off leisure battery.
I have an invertor,and was going to run all 3 off of that.
Does this mean I will have problems/need to get a 2nd Leisure battery!!!
No, the problem Fay is having is with the SX needing it's own power.
Although depending on the size of your battery, you may have trouble - or not.
If you haven't already, try all your stuff set up how you intend using it during the day and see how long the battery lasts.
Image the wall again  ;)
Or better still a clock - won't have to time anything then  8)
Yep. Set it up and try it out.
It's normally not a good idea to run a laptop or other devices on the same power line as the camera as electronic noise can be introduced into the circuit degrading your image. Although depending on your set-up and quality of equipment it may be negligible.
QuoteYes, I only use it for dew heaters. All my batteries are charged after every session. I should think about a leisure battery, but they are too heavy for me.
Those dew heaters draw quite a large current normally, 2-3 amps, so your 17AH battery will last somewhere in the region of 3-8 hours normally,
As for the laptop, hmmm difficult question to answer,
It says in their post parallel port? i thought they were usb ports! anway.
Just plug something you know to be working into each of your ports, USB, Serial & Parallel, if they all work, then they are fine,
That's probably the easiest way for you to test them.
As for the inverter being inefficient,
http://www.maplin.co.uk/Module.aspx?ModuleNo=48723 90% Efficient.
so in a word no, you lose only 10%
Laptop power assuming 150W = 12.5A off of 12V
17AH battery would last. 1.3 hours powering the laptop
with the invertor powering the laptop you loose 10%
so it would be rougly 1.2 hours
roughly 6mins. different due to inefficiency.
As Darth Vader once said, "use the invertor". or was that "Use the Force" ;)
might sole those niggling problems,
Anyway, I though you might have used the mains down there this time.
Mac, the webcam is serial, don't have a parallel, that is ok.
  It was just a thought, i will bring invertor with me to DSC. So do you connect inverter to battery & then still plug two items into inverter?
QuoteIt was just a thought, i will bring invertor with me to DSC. So do you connect inverter to battery & then still plug two items into inverter?
you can, or you can use their mains.
I've got a spare lead, you can borrow
You should at least try the battery/inverter thing to find out what your limit is should we end up somewhere without power.
At least give it a shot indoors.
well Mick, I want to use SX for guiding, I usually use webcam, so can always use that. I seem to remember my batteries were always running down too early
QuoteIt's normally not a good idea to run a laptop or other devices on the same power line as the camera as electronic noise can be introduced into the circuit degrading your image
Well I might get away with it then because I'm only planning to use the SC3 for guiding, and the camera has it's own battery.
I'll give it a try before DSC.  I have a car size 12V battery btw.
