M51 from France
Started by MarkS, Mar 29, 2008, 13:01:06
I'm spending 10 days in SW France for Easter.  Weatherwise, the worst Easter I have known in France.
But last night (the 8th night!) the skies cleared enough to get 2 hours worth of 5 min subs over a period of 4 hours between the clouds.  The usual thing:  unmodified Canon EOS 300D on the C11 with a F6.3 reducer.  Guided by a 300mm Nikkor lens with an unmodified webcam stuffed in the back.
Maybe I can get some more data tonight.  This is still a work in progress - all I've done is a straight stack and some dynamic range adjustment.  Shown below is a crop of the fullsize image.  It's amazing what a difference dark skies make!
Wondered where you were, Mark. You have done well, yes, what a difference dark skies make! Look forward to the end product.
Now re-processed using IRIS.  I'm pleased with the result:
Mark - that's brilliant - I'm not suprised you are pleased... It's amazing the images you are getting using a standard EOS300D..
Great shot - John
I agree Mark, wonderful!
Another excellent image Mark, you never cease to amaze me what you can get from that camera.  If you ever fancy an upgrade then there's always one of these ...
http://www.centralds.net/en/index.htm
Wow. That really makes a difference. That is an excellent image.
What a camera, Robert, wonder how much it is
Approx $2400 inc. derivery :)
Thanks for all your positive comments.
Robert raised an important and interesting point - cooling.  The ambient temperature was 8C when I took that image.  But CCD thermal noise doubles for each 6C temperature increase.  My calculations indicate this will have a noticeable impact on image quality in the summer months when the ambient goes up to 20C ( 4x as much noise ) or even 26C ( 8x as much noise ).
Lovely image Mark,
until you see images like this, taken with the Canon, you would be out buying astro-cams costing and arm and a leg, not knowing the full potential of the DSLR.
These images only encourage me to try, weather permitting :roll:
