Slow Access...
Started by JohnP, Dec 21, 2005, 10:02:02
It always seems really slow accessing the OAS homepage - It takes an age to load the homepage - I don't seem to have this issue with other web pages. Sometimes it can take >60secs for it to load..... Is there a problem?
Thks,  John
just tried it myself and it seems fine. Ironically, those pages are hosted on Demon's servers and should be 100% available, now the gallery archive is a different matter...
Rick's away on holiday at the moment, but if it persists we'll take a look at it when he gets back.
Must be something to do with my computer setup... It's just really slow - I'll have to try accessing the forum pages directly rather than going through the homepage all the time...
Thks,  John
hmm, anyone  else having problems?
Ian,
i have also noticed of late the time it takes to load the home page and last weekend done what John suggested today and by-pass the home page and created a shortcut straight to the forum.
I will at some point each month have to check the home page just in case i forget the dates of meetings etc. (it has been known) :oops:
Ian,
I tried with both my desktop PC & Laptop & both have the same problem. The homepage can sometimes take >1min to load but all other webpages & direct link to the forum page work fine. Both PC's were using same NTL Broadband connection so maybe it's something to do with them....
Tony - Long time since you have posted... How you getting on with Imaging & your new scope....?
Cheers,  John
John,
with the weather and all, not much. Have posted on the Technical forum.
I suggest, for the present, until I can find a way to fix things, that you disable JavaScript and try again. I think that will speed up acces quite a bit.
