Iris Nebula NGC7023 and Gyulbudaghian's Nebula LBN468
Started by Carole, Sep 14, 2021, 16:54:23
Co-incidentally Mark has just done the same image (only his is much better).
I went to a small star party in the Cotswolds last week Bortle 4 and the skies were clear for the first 2 nights.  This is the first of 2 images I managed to get.
Because i don't do much in the way of LRGB imaging I found this particularly difficult to process, but Peter Shah was at the Star party and gave me a few tips.  It didn't help that I stupidly forgot to put the cooling on (Gun to head).  Also 2 sides of a Median to process just to add to all the problems.
Like Mark i have been wanting to get these two targets for some time, but unless I did a Mosaic and with my LRGB opportunities this would be somewhat problematic, so I decided to use my Samyang lens.
Atik460EX and Samyang135mm lens @ F2.8
Lum 23 x 600 (3hours 50mins)
RGB 14 x 150secs binned each filter (35m each) total 1 hour 45 mins
Total imaging time 5 hours 35mins
That's come out really well Carole!
You have a larger field of view than my image.  Which camera and lens was it and what f-ratio did you use on the lens?
Thanks Roberto and Mark.
QuoteYou have a larger field of view than my image.  Which camera and lens was it and what f-ratio did you use on the lens?
Really Sorry, I forgot to put that.  It was my Atik460EX and Samyang135mm lens @ F2.8
Will now amend the first post.
I had an even bigger FOV but due to changing my equipment around, I messed up the orientation of the mounting of the Samyang set up and had a rather large amount of rotation each side of the meridian, so this is cropped to get rid of the overlaps.
garrick
Great image! he dust clouds look amazing.
Clear Skies
G
Dead chuffed to receive the following message from Astrobin:
"Congratulations! Your image was nominated to be a Top Pick: Iris Nebula NGC7023 and Gyulbudaghian's Nebula LBN468"
garrick
Congrats. That's a brilliant result.
Best wishes
GW
Quote from: Carole on Sep 16, 2021, 19:06:32
Great image and FOV and well deserved the nomination
Rog..
That's really rather good Carole. Maybe you shouldn't bother cooling that camera!
Thanks Duncan, lol, yes I thought it would have been much more noisy.  But I won't take that advice ha ha.
I must say i have been quite chuffed with how it turned out in the end, but it was a challenge processing it.  especially 2 sides of Meridian for all channels and I don't get much practice with LRGB.
AndrewRamsay
Very impressive.  No wonder you got a "top pick".
