NGC7380 | The Wizard Nebula
Started by garrick, Sep 12, 2021, 20:28:59
garrick
PreFinish_Crop_1_Astrobin_OAS by Garrick Walles, on Flickr
Imaging telescopes or lenses: William Optics GT71 II APO
Imaging cameras: ZWO ASI 294MM Pro (cooled) ASI294MM PRO
Mounts: Skywatcher HEQ5 PRO (belt modification)
Guiding telescopes or lenses: William Optics 50/200 GuideScope
Guiding cameras: ZWO ASI120MM-S ASI 120MM-S
Focal reducers: Hotech 2" SCA Self-Centering Field Flattene Hotech 2" SCA Field Flattener
Software: PixInsight 1.8.7 Ripley PixInsight  ยท  Asi Air for IOS
Filters: Baader Ha, OIII, SII 1.25 inch
Accessory: ZWO ASI Air
Dates:Aug. 28, 2021
Frames:Baader Ha, OIII, SII 1.25 inch: 242x180" (12h 6') (gain: 120.00) -10C bin 2x2
Integration: 12h 6'
Darks: 41
Flats: 41
Flat darks: 41
Avg. Moon age: 20.54 days
Avg. Moon phase: 66.76%
Bortle Dark-Sky Scale: 8.00
Your link sends me to a Flickr login page, so I wasn't able to see the larger version.
It looks pretty good from the small version you posted.
garrick
Thanks Mark. I'm completely new to Flickr, so am not sure how it all works with links. Maybe you have to be logged into Flickr. I don't know, but will look into it.
There should be a full size image in the OAS Gallery under my works in progress.
Have a good day and clear skies
G
Quote from: garrick
I don't know Flickr either but I was able to see your "Cygnus Region and Friends" image on Flickr without logging in.
That's an excellent picture of NGC7380.  Well done! 👍
just had a look at your flickr photo, it says its private....
:cheesy:
Using flickr.
When i link from my flickr stuff i do it this way.
Select the image size you want to share, I normally just select the 1024 size and open the image, (link below)
That link is the link i share to display the image links and all their sizes
https://www.flickr.com/photos/193932661@N04/51457561137/sizes/l/
then right click the image and open that image in a new tab and then use that image link to physically share the image, as below. (i selected the 400 this time)
After you open the image in a new tab you get the following url.
https://live.staticflickr.com/65535/51457561137_b1aa4b03e8_w.jpg
That is the full url for your image which you get from flickr.
Below
garrick
Thanks Mac.
Really useful info regarding Flickr.
I made the image public. You were correct, for some reason it was set to private.
Hopefully that should sort it out.
Thanks again for your help.
Clear Skies
G
Another excellent image.  You're going to be a great addition to the imaging team.
That's a beautiful image and well processed!
By the way Garrick, if you have uploaded images to the OAS gallery, you can link them from there, this will enable every-one to see them without having any problems with Flickr.
