North America Nebula - The Wall
Started by Carole, Nov 12, 2016, 20:05:58
This was the image that I struggled with on Guy Fawkes night in my "Trials of Imaging" thread.
As stated I had trailing problems with subs longer than 500secs, so had to do a little bit of cheating on this process, I erased the stars on the 15min image stack using Straton, and then overlaid the 500secs Ha subs which put the stars back.
Get so little time to image these days I didn't want to waste the data.
This is another example of where I probably need dark skies for the Oiii and Siii components, though I have never done such short binned images before, so maybe I should have taken longer subs (was experimenting). Wasted so much time trying different length Ha subs to see where trailing started which prevented me from doing more subs of Oiii & Sii.
First light for my SW130PDS, Atik460EX, NEQ6, PZT
Ha 5 x 900secs + 2 x 500secs
Oiii 3 x 150secs binned
Sii 4 x 150secs binned
Looks better if you don't zoom in.
I like it.  It obviously needs a lot more data but it's looking good.
Thanks Mark, yes trying to get enough data is a real problem given the weather.
julian
That is looking very good Carole.
I have brightened and sharpened it up a bit, also tried to reduce the noise.
Thats is really nice Carole, you earnt it!!!!
Nice - there are quite a few hot pixels on full size image?  John
You're right I had not noticed them.
That's looking very good Carole.  As John pointed out there are a number of hot pixels but it still shows much promise, you just need a bit of extra data (as we always do).
Thanks Robert,
Well hopefully I shall be able to get some more data before Cygnus disappears so I can keep the camera orientated the same.  This should act as a dither, so hopefully will eradicate the hot pixels.
