Discovery of of rare dwarf satellite galaxies orbiting our own Milky Way
Started by Carole, Mar 11, 2015, 20:46:54
Welcome to the neighbourhood: new dwarf galaxies discovered in orbit around the Milky Way
A team of astronomers from the University of Cambridge have identified nine new dwarf satellites orbiting the Milky Way, the largest number ever discovered at once. The findings, from newly-released imaging data taken from the Dark Energy Survey, may help unravel the mysteries behind dark matter, the invisible substance holding galaxies together.
The new results also mark the first discovery of dwarf galaxies – small celestial objects that orbit larger galaxies – in a decade, after dozens were found in 2005 and 2006 in the skies above the northern hemisphere. The new satellites were found in the southern hemisphere near the Large and Small Magellanic Cloud, the largest and most well-known dwarf galaxies in the Milky Way's orbit.
More on the Cambridge University website
