Taurus, Pleiades and Lovejoy from Stonehaven
Started by Kenny, Jan 17, 2015, 03:19:52
Kenny
My attempts this evening. Canon 450D. Processed (JPGs - need to work out the problem processing my RAWs) without darks / flats / bias in DSS (may re-attempt over the weekend).
Earlier in the evening (17:51) from the War Memorial over Stonehaven.
Later (18:47) when that part of the sky was a bit higher, taken from Dunnottar Castle carpark, a less windy spot.
Getting very bad distortion at the boundaries of my images. Really shows up in the top left of these images.
Gosh you have been busy.
Re:distortion  - some lenses are more equal than others. I am new to the widefield game as well, that's why I got the StarAdventurer to have a go. I am playing with a Pentax 50mm which is really fairly good to the edges (£35 on ebay + adaptor for Canon) and two Nikon zooms I happen to have, the shorter standard kit zoom is bilge (see my earlier Orion shot) but the ED 70-300 seems quite acceptable at both ends of the range. Again with a Canon adaptor from ebay.
Kenny
Another go last night from the same location, albeit a bit rushed after I'd done my War Memorial star trails. Not much improvement but can see the movement vs the previous capture. I think the focus was slightly off as well.
Canon 450D. 20 x 13 sec exposures at 18mm, f/5, ISO-1600.
