HEQ5 alignment
Started by Kenny, Dec 19, 2014, 17:00:27
Kenny
I'm really having trouble trying to align the OAS HEQ5. I've got the scope roughly polar aligned and it's in the home position (scope pointing at the pole star (not that I can see that right now). I've chosen 2 star alignment. 1st star - Vega. Within 1 second of it starting to slew towards Vega it stops and completely resets the Synscan so I have to re-enter date, time, location, etc.
Any bright idea? Am I missing a crucial step or is something not working as it should?
That is typical of a voltage drop during the slew. Check power, leads, connectors.
MarkH
This happens with my Meade gear sometimes, glad I'm not the only one.
Kenny
Quote from: MarkS on Dec 19, 2014, 17:31:14
Thanks Mark. Problem solved. I was powering from a mains charger. I switched to the battery and it's all working fine.
Welcome to the trials of imaging Kenny, this is the first of many.   :cheesy: :cheesy:
But when that first LX image hits the PC it will all have been worth it.
Kenny
Ha ha. Yes. It's been a sharp learning curve, both the trials/tribulations and the rewards. :)
Kenny
Quote from: Mike on Dec 21, 2014, 16:06:04
You have an LX?
No. A 6" Newt and 8"Dob. It was Mark that mentioned the Meade.
p.s. I had the mains cable set to the wrong voltage. It was fine with tracking but not enough juice to slew. Newbie error.  :oops:
QuoteYou have an LX?
Sorry Mike, I confused the issue by referring to Long Exposure as LX.
