The Wall part of NGC7000 in Cygnus
Started by Fay, Oct 09, 2009, 11:15:24
I have contacted Pulsar Optical & they say they do a pier extension. I said I would like it to be 4-6" higher to avoid shelf collision.
Waiting to see what they suggest.
All your cables will have to be 4"-6" longer as well then  ;)
So you can go a couple of feet higher on the pier then ?
Do you have a ladder  ;)
Fay,
I was just waiting for you and Mick to finish discussing the shelf on the pier to say what a great image you produced, even if the shelf gets in the way.  ;)
I wish I had a shelf like that, so I could get some good images.  :-?
Why would you want an image of a shelf ?
I didn't, I thought it was a new type of camera or something.  :-?
I was thinking.....if I get a 5" pier extension, i would have to have a mount bolt 5" higher, also a bolt that long may not fit into the owls nest for insertion into the mount.
I would have thought the pier extension fitted between the owls lest and the pier, so the mount bolt should still be OK.
Or have I got it all wrong again  :oops:
Well the owls nest is firmly fitted
