NGC6960 The Veil 19x300 SW120, QSI 7nm ha, o.85 fr 270911
Started by Fay, Sep 28, 2011, 17:40:42
They rely on you adjusting the controls to get the best balance.  Generally they both sharpen and noise reduce so it's a balancing game but as always the defaults do a reasonable job.
I'm sure I have my NN activation key around somewhere if you want to give it a try in PS.
PhilB
Very nice detail, Fay. Makes the case for B&W imaging!
thanks for that Robert, it would be nice. I know why I had trailing stars, the pier had slipped out of polar alignment, Guiding graph was ok, but in the dark, i took evertthing off to try to sort it, as too heavy with that 120 on. Set it all up again & it was still trailing. So put it all away & had another gho. Bit sad, as perfect night.
Thanks Phil. I was not too happy with the image, there is a lot of detail on there, but bad stars & background. I was surprised to get anything & thought I would have to throw all subs away, as I was aware I had a problem last night.
