eyepieces
Started by MarkH, Sep 24, 2014, 21:00:31
MarkH
Can I have some opinions here. If you were to spend £200 on a 1 1/4 " eyepiece say between 15 -28 mm or near, as wide as possible, what would people recommend from experience.
That's expensive for a 1 1/4 inch eyepiece.
Check out www.excelsis.com for ratings plus also Cloudynights.
I think your best bet is likely to be a secondhand panoptic or something similar, even so they will probably have a 2" barrel or both like my Meade 14 UWA.
Hope that helps
i've never spent more than £100 on an eyepiece, some of the cheaper 1.25s (£30ish) are excellent.
Hugh
Try looking at the Tele Vue Delos range ~ 72 degrees apparent field ~ 20mm eye relief.  But may be only a 17.5mm within your size range.
It will push your price to around £250 but I think worth it.  I have a 10mm which you are welcome to try if you want.  Jim has tried it and thinks it great.
If you can wait, you can get a good discount at Astrofest.  I even got the box signed by Al Nagler, which makes just the box worth about £10!
Hugh
MarkH
Thank you all guys, that is all very helpful. Hugh I think your suggestion is what I'm looking for.
