EQMOD Arrgghhh
Started by MarkS, Sep 02, 2013, 22:04:31
0 Members and 5 Guests are viewing this topic.
Do you have any software running that is looking for low battery ?
I believe APT gives a warning (or does something) on low camera battery.  Not sure if it's camera specific but most features can be turned off.
Quote from: mickw
Catch-22
The low battery happens during slews.  When it happens the Camera can't communicate.  So the software just sees a comms failure.
You could possibly solve spikes on the lines with some capacitors to act as filters.
Quote from: Mike
You reckon voltage spikes could be part of the problem?
It is certainly a possibility. In most electronic circuits that have communication sections unfiltered power sources can wreak havoc and cause constant comms. issues.
You could place an inducter in series with the supply and a decoupling capacitor across it to smooth it out. Another option is to run the 12v through a fixed voltage regulator (DC-DC converter). Most DC-DC converters have other circuitry to filter out noise too. However, getting one for the ampage you require would not be cheap.
If it was me, I would ditch the battery and get a properly regulated power supply.
Such as: http://www.rapidonline.com/Electrical-Power/Rapid-4A-13-8V-Fixed-Output-DC-Regulated-Power-Supply-Linear-Mode-77155
Another option is an ATX PSU from a desktop PC which also has 5v and 3.3v outputs. They have plenty of amps and as they are designed to power a sensitive PC motherboard are well filtered too. They are also cheap.
This shows you how to modify one nicely:
http://www.instructables.com/id/Convert-an-ATX-Power-Supply-Into-a-Regular-DC-Powe/
A laptop with enough USB Ports?
Quote from: MarkS on Oct 02, 2013, 10:29:03
Quote from: Mike
This Capacitor should solve any load problems!
