IC5146 Cocoon Nebula
Started by Fay, Jul 09, 2013, 15:08:53
9x900, QSI, 0.8fr, 7nm ha, SW120
beem about 5 months since last image. i was just glad that all equipment worked very well need more on this one.
http://www.flickr.com/photos/moondust/9245949223/lightbox/
Looking very good Fay and nice stars.
Can't see the option to view full sized in Flikr  :-?
link under the picture mick thanks flickr has changed its layout, i am still figuring out how to do what!
Followed the link but image the same size as on here
if you click the picture on FLICKR, i am thinking it should come up full screen, but nothing happens
Thanks Mike.
Just found out how to view the sizes as well - The 3 dots bottom right give the option - must remember that
im still figuring out how to edit description
ok three dots does it all!
#10
i think this crop is better
It will only be better if there's nothing extra when you add more data  ;)
Needs a bit or colour ;) but it's an excellent start.  I'm glad all the equipment still worked - that must have been a relief !
That's looking really good Fay!
Everything has clearly worked very well.
thanks a lot. i know it needs more, but would you believe a had a very smooth trouble free setup etc etc does not happen often
