M27 HaRGB WIP 6-7-13
Started by Carole, Jul 07, 2013, 13:36:55
This is the first time I have imaged in 2 months.  Have been beset with problems both on the domestic front and with trying to get flats to work on the Newtonian with the Atik Mono camera.  I was getting some awful artifacts with the Atik flats and after much frustration and head scratching I finally realised that my manual filterwheel leaks light and therefore flats have to be done at night.  But having bought myself an EL panel, it was still not removing dust bunnies.  Have now discovered that I dare not move the filter wheel until after I have done flats as with a manual filterwheel the dust can move.
I wanted to see if I could get the skirt around M27 and happily I can see it on this Ha image.  I am planning to try to add colour to this tonight to complete the RGB bit of the title, with the QHY8L, so this is a work in process:
OK, waffle over:
11 x 1200 secs 7nm Baader Ha filter with Atik383L @ -15 degrees
Skywatcher Newtonian 200 PDS with coma corrector I think this is f4.6 (ish)
Captured in artemis and processed in DSS and PS CS3
NEQ6
As this is a Crop a full frame is not that brilliant, but it's on the gallery if you want to look
Well that's showing up very nicely Carole - a great start - the 7nm Baader is great at blocking out all the crud...
I tried this myself almost a year ago from bromley with 7nm + Atik 314 - through ED80 with similar exposure 10 x 10mins  - Interesting to compare the two - you captured a ton more stars - I am guessing due to faster focal ratio of scope..
http://jpastronomy.co.uk/graphics/2012%20Atik314L/m27-10x10mins.jpg
Nice one - John
You did well, Carole, stars and detail very good
Thanks Fay.  Yes John, it was your image that inspired me to give this a "go".
Nice image Carole with lots of detail. Looks on the soft side to me though, unless it is how it was processed.
Thanks Mike, I never really know what people mean by soft:
Slightly out of focus, or not sharp edges?
It could be the way I processed it as I don't like stars to be white blobs, I like a slightly "rounded" edge to them.  Also this being a CROP might show up any imperfections.
I got some OSC data on this last night, just going to do my flats and process it (hopefully these can be done during the daytime as no filterwheel to leak light!!! :cheesy:
Yeah, as in 'soft focus'.
Thanks Mike, yes I think you are right.
If the raw frames are sharper then perhaps its the processing. Or try some unsharp mask on it after stacking.
I'll take a look at the Raw frames.
I've checked the subs and the unstretched stack and I think it's the processing.  I think it's my efforts to pull out the faint skirt that did it.
Will try a re-post-process when I add the colour.
Nice image Carole - especially to get that shirt appearing.  Unfortunately it is true that if you stetch an image enough to make very faint detail (such as the skirt) appear then it will also make the stars appear big and blobby.  I can't see any way around that without somehow processing the stars differently to the nebulosity.
Thanks Mark,
Hopefully some colour on the way.
Will have a think about the processing when I re-do it.
That should end up being a really good image Carole but you need to get to grips with stretching the faint nebulosity without the star bloat.  You're fairly determined so it shouldn't take you too long to get there :)
Quote from: RobertM
... you need to get to grips with stretching the faint nebulosity without the star bloat.
I'd like to know how to do that as well!
