Finally
Started by mickw, Apr 04, 2013, 09:09:08
You'll no doubt need to play around with them to suit your kit. I use a small 60mm finder scope as my guide camera so these settings suit that scope. I'm guessing you would use an 80mm guide scope or an OAG so you might need to play around with either the timing settings or the aggressiveness to suit your set-up.
I agree but at the moment the QHY is on the back of a 50mm guidscope so the settings shouldn't be out by too much
They will probably work then.
Sorted - possibly  8)
At last all the software seems to be working and talking amongst themselves, the hardware all seems to be operating correctly as well.
I'm just going outside to set for a proper test  :)
Oh hang on it's raining  :( :( :( :( :( :(
