IC434 - separating Alnitak
Started by Ivor, Nov 20, 2012, 22:36:56
Quote from: Ivor
found it, you have to be x1 scale.
Oh yes, I've hit that before - anything that involves selecting or adding points on image will only work at 1:1 scale.
Ivor
Starting to get the the stretching correct in Iris however saving it is presenting a problem, the save function in the file menu and button don't appear to save the visualised image?
Tutorial on the Iris don't mention anything so I must be missing obvious step?
Another hint please?
If you save as a BMP then you get exactly as it appears on the screen.
If you save as a TIF then first set the threshold sliders to 0 and 32767 and then multiply image by a constant "mult n" and maybe add an offset "offset n" so it looks right on the screen before saving.
Ivor
#18
After a number of emails with Mark (thanks again) and much plotting in Excel to work out how asinh works I got it straight in my head and I think I can do it correctly in FITS liberator now.
After various processing in PS this is the end result of
RGB 8 -  x 10mins Ha - 11 x 10mins
Stacked in AA5
FLT110 ST8300M
That's looking really good Ivor.  The structure in the nebulosity behind the horsehead has come out really well.
I'm not too sure about the colour however - maybe it's a lack of blue - I'm not quite sure.
You have succeeded in getting Altinak under control.
Overall it's a very good result.  Well done
