Author Topic: Database problem...  (Read 1849 times)
  • Administrator
Database problem...
« on: Nov 15, 2012, 09:56:01 »
The problem this morning, which resulted in the message:
Code: [Select]
Table './orpastro_smf/smf_sessions' is marked as crashed and should be repaired
...was fixed using this hint.
Please let me know if fou have information about when (and why) the problem started. Earliest report I received was from Mick at 09:11. Cheers, Mick.  :beer:
Edit: Ok... The database backup I run automatically in the wee small hours also failed, and the gallery has had a similar problem which I've also fixed... I suspect a server glitch.  :unwell:
« Last Edit: Nov 15, 2012, 10:15:28 by Rick »
  • Exile Under Darker Skies
  • R.I.P.
Re: Database problem...
« Reply #1 on: Nov 15, 2012, 10:16:44 »
Definitely down before 08:00 with same message
  • Administrator
« Reply #2 on: Nov 15, 2012, 10:27:18 »
Yes, the last time I know it was up was 00:06 when you posted a reply to Fay's Google thread. The earliest indication of a problem was in my backup scripts at 04:30-ish, so whatever went wrong happened sometime between 00:06 and 04:30...
  • Administrator
« Reply #3 on: Nov 15, 2012, 13:08:39 »
...and the hosting company have confirmed that the MySQL server had a problem in the same time window.
