NGC6280 (Open Cluster) taken at Rothe Valley 15 Sept 2012
Started by The Thing, Sep 21, 2012, 20:00:16
Not sure if this is actually what it should be according to CdC as I can't make out the open cluster against the rest of the stars. I imaged the area anyway as I liked the dark nebula and the zillions of stars.
Aha! It's a galaxy according to Deep Sky Object Browser. It's the tiny orangey blob near the left edge half way up. Must be more careful selecting things in CdC!
HEQ5 Pro (recently re-greased), EQMOD, CdC, LX90 8" UHTC Baader Alan Gee II Telecompressor, Canon 350Da, NO Astronomik CLS-CCD clip filter, Lakeside ASCOM Focuser, Meade 8x50 FinderGuidescope & QHY5, PHD Guiding, APT Astro Photography Tool.
Processed in IRIS. 10 flats, 8 darks, 10 offset/bias frames. 20 x 300s (1h40m) at iso800. Stacked with sigma 1.5 with 1 iterations. Colour and dynamic stretching, wavelet sharpening and binning twicex2 (which means Mark the big version was binned x2, the small version was binned again x2 to make it smaller).
Larger Version
Actually I quite like this.  Apart from the galaxy there's a nice variation in star colours and there are definite patches of dust.
To the best of my knowledge, this is not a area of sky that's frequently imaged!
I like it too, love the star colours and dark nebula.
Your optics seem to have recovered Duncan, or is this a different telescope?
Quote from: Carole on Sep 21, 2012, 23:46:02
Thanks Carole. Same scope etc. Just have tweaked the mount for smoother guiding (lots of grease everywhere), cleaned the optics and drank a lot.
I have solved the image in Astrometry.net. It's between Vulpecula and Albireo (which was where the scope was pointed). Center (RA, Dec):   (295.548, 27.313)
That really is very nice Duncan, great colour & lovely stars
Yep agree with all comments Dunc. Your images have come on leaps and bounds since you 'stripped your mount...'.   Oh err Miss's
Very nice wide field.
John.
John.
This is very nice Dunc
I may be wrong (nothing new there) but you seem to be processing a lot more/better.
Is it your switch to Iris ?
Everything seems much more detailed with cracking colours
Its IRIS. Follow Marks crib sheet and instructions for gradient removal  and you can't go too far wrong.
Jim
Really nice Duncan. Be nice to do a star count; anyone know how to do that?
Quote from: Jim
IRIS!
On Duncan's jpg I ran:
setfindstar 1   (this recognises a star as being anything brighter than 1 std dev above the background.
followed by
findstar
It found 7,100 stars but I reckon it had still found less than half so there's at least 14,000
Duncan, if you run the commands on the original you might get a better result.
On the original PIC file IRIS says "Warning, too many stars"  and returns:
7572 at 1 sd
8510 at 1.5 sd
8744 at 1.75 sd
8510 at 2 sd(?)
I suspect that the dimmer stars are too close to the background level to be detected .
