First Light Lunt LS60 B1200
Started by MarkS, Jun 09, 2012, 19:10:18
The sun finally came out!
I used the QHY5 for this - 200 frames of 5ms processed in Registax.
Not really sure why there's a top to bottom gradient.  I lost the prominences during processing - I need to try again so I can bring them out.
The colouring is false colour of course.
Full size version here:  http://www.markshelley.co.uk/Astronomy/2012/sun_09062012.jpg
well I can see some little prominences... Very nice surface detail - If anything you could brighten it up a tad...
Looks promising though - John
Nice Mark, I was looking at that super bright active region earlier thru my scope. Love these Lunt scopes they are great fun, and you don't get cold using them either  :P
Quote from: Whitters
www.spaceweather.com says that bright area is currently crackling with M-class flares.
Very nice Mark.
I think there is always a gradient with solar imaging - so I have been told.
Some nice detail there, as said above it needs brightening a bit and perhaps some increase to the contrast to bring out those nice features.
Quote from: MarkS on Jun 09, 2012, 19:10:18Not really sure why there's a top to bottom gradient.
The filter on my PST is extremely angle-sensitive. Might the gradient be related to angle-sensitivity?
That bright active area was central and very distinct during the Venus transit (when there were no clouds in the way).
Here's a reprocess of the data to remove some of the brightness "banding", to make the prominences a bit brighter and to increase overall contrast.  I also used AviStack instead of Registax.
The banding (in brightness and surface detail) is apparently caused by the tilt etalon.  The pressure tuned version of the etalon is supposed to be superior in this respect.  Anyhow, now I'm aware of the issue I can tweak the etalon to give the best compromise between banding and detail.
Full size here:
http://www.markshelley.co.uk/Astronomy/2012/sun_09062012v2.jpg
I'm still not entirely happy with the processing.  I need to play with the sequence a bit.
Well it look pretty good to me - reprocess is a lot better - John
Nice one, I agree the reprocess is a lot better
When you sleep now?......... :o
Quote from: Tony
That's the purpose of cloudy weather!
Quote from: MarkS on Jun 11, 2012, 15:11:16
Quote from: Tony
The way this weather is going, I can see 'Rip Van Winkle part 2' coming.
Much happier with this one, finished off in PixInsight ...
Full size:
http://www.markshelley.co.uk/Astronomy/2012/sun_09062012v3.jpg
Oh yes, that's a big improvement Mark.  Really like that.
