First Startrail
Started by Fay, May 12, 2012, 17:01:20
It's not 'feint' it's 'faint'.  A feint is a deceptive movement - ah um, is that what you meant  :lol:
I like that a lot Fay!  The second version is definitely better.
I can't add much that hasn't already been said.  However it does appear that the lens has aberrations out towards the corners which are causing the thicker trails.  Maybe stop the lens down a bit further next time.
BTW Apocalypto Wednesday night BBC4 22:40 - I've heard it's a good film!
You are right Mark, the lens is causing the thicker trails on the outside.
You beat me to it regarding Apocalypto, i have also heard it is a good film.
You going to DSC?
