M81 LRGB with some IFN
Started by Rocket Pooch, Feb 22, 2012, 15:22:39
We have spent about two hours processing this to get the IFN into the image.
This is 16 10 minute L, and 12x5 min RG and 16x5 min B.  Usual processing except the colour balance was done in PixInsight.
LRGB
LRGB HDR FINsRGB by chrissuddell, on Flickr
L
M81 IFN LUM by chrissuddell, on Flickr
Wow!
That is really impressive.  A very deep image with a large number of background "fuzzies".  The intergalactic flux is also beginning to show quite well.
You must be really pleased with that.
You've even produced a monochrome version for Tony's benefit  :cheesy:
Superb mate - the sort of image that wants to make me move to Les Granges... At full size you could crop the individual galaxies by themselves & they would be fantastically detailed images in their own right & then put them together with all that dusty stuff in between....... drool.....!!!!! Looks like You & Jim have had some great weather this week.... Nice one.
Quote from: MarkS on Feb 22, 2012, 22:19:09
I do like a Mono.  :D
Excellent image.........................high five. ;)
Thanks guys, high five.
You should see Olly's version with the 14" and the Mesu mount  :o
I took the night off last night after pulling one 5:30am and three 3am nights.  It was clear last night again and I can hear Jim whooping with delight over his laptop, not sure what that is all about!
Is that your TAK or Olly's you are using?
That was with the FSQ85 at prime, Olly's.  But I set it up focused it, worked out how to get the Tak mount working with ASCOM, used my camera and processed it, so its my image!!!!
I was just curious if you'd been brave enough to go spend the £3500 they cost to buy one !!
Quoteso its my image!!!!
... OK calm down calm down.....  :)
Judging by your image, that scope is certainly giving a very flat field with sharp stars from corner to corner.  The very slight elongations in the corners are barely discernable but are symmetric.  It's nothing to complain about.
FSQ85?  A tempting proposition ...
I think the rotation was because the guide scope was about 10deg out !
But the scope is sharp....
How about swapping your Banana for one and getting a cooled CCD?  Hmm.
P.S. The sky reading here is 21.8.
