Perseus Double Cluster
Started by RobertM, Dec 03, 2011, 16:12:40
I knew it wouldn't be long before started blowing things up  :roll:
Very nice image Robert
Quote from: The Thing on Dec 04, 2011, 10:20:27
Quote from: RobertM
One possible explanation is that the camera cables (which are quite thick) are causing it - look at the direction of the spikes - they are all aligned exactly the same way as the elongation.
On the basis that a curved spider vane creates self cancelling diffraction artifacts i.e. no spikes, could you put in a curved cable guide e.g. a bit of coat hanger wire, attach the cables and get rid of those pesky spikes? Not that I can see any spikes - must get an eye test soon!
Thanks Duncan, I'll give that a go.
