Heart & Soul QSI/LEITZ
Started by Fay, Nov 18, 2011, 14:41:35
One sub test of QSI & WOZS66 with dedicated flattener. i thought i had focused before I zoomed in. I should have made this another post
Does the flattener not match? Or is it out of focus?
Do you have the correct spacing between flattener and CCD?
Fay, It's fine to link to huge versions if you like, but please can you put slightly smaller versions inside the IMG tags?
ok Rick
Perhaps not Mark. I had to add the QSI spacer, which screws into the camera & into the flattener. Or the camera may be too heavy for the focuser tube, as it has to be quite a way out
What do you think?
Does the QSI spacer put the flattener at the correct distance from the QSI ?
perhaps not, will have to do some testing & see if I have a narrower one that fits
