Author Topic: My manic solar system 24 hours!!!!  (Read 6682 times)
PhilB
  • Star Class
Re: My manic solar system 24 hours!!!!
« Reply #30 on: Sep 14, 2011, 18:55:11 »
The images look much improved, Carole. When are you going after the other planets to complete the set?
“Never worry about theory as long as the machinery does what it's supposed to do.”  Robert A. Heinlein
    • Carole's images
« Reply #31 on: Sep 14, 2011, 19:42:55 »
Funny you should say that Phil, but I have just made the decision to try to do just that, though I think Neptune is going to be a bit of a challenge.
I've made a Mosaic with what I have done so far (except Earth of course) with the aim to try to fill in the missing ones:
Obviously not to scale:
    • Carole's images
« Reply #32 on: Sep 15, 2011, 09:47:31 »
Collimation on ETX125 checked last night (Wednesday) and all is well.
  • Galaxy Class
    • smile
« Reply #33 on: Sep 15, 2011, 12:27:40 »
Quote
I diddnt think the ETX 125 could be collimated, as they are Maksutov designs.
http://www.weasner.com/etx/warnings/collimation-warning.html
    • Carole's images
« Reply #34 on: Sep 15, 2011, 12:30:56 »
Neither did I Mac which was why I never bothered to check it.  But someone suggested that the collimation might be OUT.  I actually had a look on line and there is some-one who has done it, but you have to open up the plastic casing at the back and then collimate it like a Newtonian, but apparently the screws that you need to turn are sealed and you need to break the seal.
Anyway academic now as it's OK.
    • Carole's images
« Reply #35 on: Sep 16, 2011, 19:39:39 »
Someone has told me about a plugin called Focus magic.  I downloaded it and this is the result on the Tycho image.  It's sharpened up the focus a bit.
  • Galaxy Class
« Reply #36 on: Sep 16, 2011, 21:37:54 »
I didn't think the ETX 125 could be collimated, as they are Maksutov designs.
Mac,
Robert had to collimate my Skywatcher 150 Pro which is a Mak-Cass, a couple of years ago...........................................But me and Chris had stripped it down until it looked like pile of junk, and this was all due to a spider entering the scope through the open eyepiece. :oops:
    • Carole's images
« Reply #37 on: Sep 16, 2011, 21:51:00 »
It's those Spiders again.
Yes open eye pieces are a danger.  I always try to cover things methodically, but I recently went outside and found I had left my refractor open ended for a few days, I had a fit when I saw it.  Luckily it seems OK.
PhilB
  • Star Class
« Reply #38 on: Sep 16, 2011, 22:52:15 »
I found a web or two in my AT1010 when I got it - just remove the focuser and shove in a vacuum cleaner, works a treat :cheesy:
« Reply #39 on: Sep 17, 2011, 12:05:35 »
Quote from: Carole
I'm impressed with the results that Focus Magic gives - especially for such a straightforward user interface.  However you should bear in mind that the blurred image you have is more likely to have resulted from atmospheric turbulence (which cases a Gaussian blur) rather than defocusing (which cases a defocus blur).   These two types of blur are different and my understanding is that Focus Magic is aimed at defocusing blurs and motion blurs rather than Gaussian blurs.
    • Carole's images
« Reply #40 on: Sep 17, 2011, 13:03:21 »
I actually thought it was a little out of focus.  I had done a Bahtinov focus, but some-one told me the Moon is a slightly different focus to this, are they right?
Is there any way of unblurring a Gaussian blur?
« Reply #41 on: Sep 17, 2011, 13:33:34 »
Quote from: Carole
If your Bahtinov mask has corrrectly focused on a star then the moon will also be exactly in focus.  I've no idea what this person had in mind when they told you that the Moon has a different focus.
Registax wavelets are good for unblurring Gaussian blurs.
  • Exile Under Darker Skies
  • R.I.P.
« Reply #42 on: Sep 17, 2011, 13:53:35 »
I would have thought that focus on the moon would be more critical than on a star - a star being just a dot and there being recognisable features on the moon.
Being slightly out of focus on a star would show up more on the moon.
As Mark says - in focus is in focus, just needs to be precise.
    • Carole's images
« Reply #43 on: Sep 17, 2011, 14:29:32 »
Yes I thought that was a little strange about the Moon having a different focus that's why I thought I'd double check it.
  • Administrator
« Reply #44 on: Sep 17, 2011, 15:40:11 »
Either the person concerned has access to optics with a stupidly large f-ratio and therefore an incredibly narrow depth of field, or, perhaps, they actually live on the Moon. I suspect the latter is more likely...  :alien:
