Narrow band imaging,
Started by Mac, Aug 26, 2011, 18:24:49
Following on from another chat last night with Julian, regarding Narrow band imaging and DSLR's
This was the filter that I was talking about, It combines the narrow band filters for
Ha, Red
Hb, Blue
Oiii, Green
in to one filter, so using it with a DSLR should be pretty good,
as it rejects the Sodium & Mercury bands completly.
http://www.meade.com/catalog/meade_4000/meade_series_4000_nebular_filters.htm
The problem is the one I've got is still playing Hide and seek at the moment,
It look as if its available as rither a SCR Rear cell, 1.25" & 2" filter so all the bases are covered.
Might need an IR cut filter for imaging though as there doesn't look to be much of a cutoff at the longer wavelengths.
True but only if your DSLR has been modded,
otherwise the Hotfilter will do the UV & IR Filtering for you.
Must have a good look round this weekend and see if i can find my one.
julian
Thanks Mac for putting this up on the forum.  ;)
