M13 - 22 May 2011 00:00 to 02:30 BST
Started by The Thing, May 22, 2011, 16:30:39
Hi Robert,
Tuesday night had very little air movement, I double checked everything was balanced and well done up and that the cables were free and wouldn't catch anything.
I wish I had logged the guiding numbers or print screened the graph, someone might have been able to say - 'Oh yes that's the xyz being unflanged by the doodab' or something. I love these little mysteries, it would be boring if it all just worked perfectly!
Duncan, there is a setting you can/should change in EQMOD that stops weirdfulness happening with guiding
Change the default figure in Ascom Pulse Guide Settings to .5 or 5 (can't remember which) Chris told me so he'll know the correct value
Here's the menu screen - see top right
http://eq-mod.sourceforge.net/eqaindex.html
I
HI Mick,
I tried upping the setting from the minimum (as it installs) 0.2 to 0.3 and it made things worse! Maybe I wasn't brave enough.
Must have been .5 then.
Definitely improved the wayward guiding issues - IRC the pulse guide setting slows the mount down enough so it receives the command from the guider before moving
The reason for upping it is to do with calibration and guide pulses, if you galibrate with a higher number in EQMOD the stars move further and the accurate angle and rate of movement can be recorded.  Thats all.
I guess you could fiddle with PHD calibration timings?
Hi Chris,
I had already set the PHD callibration timings to 2500ms to compensate for the short focal length (190mm) finder guider scope to get the full 25+ pixel movement required in around 12 steps. Of course that doesn't affect the actual guiding. I will try increasing the EQASCOM setting and see what happens.
Yet another M13! The setup is the same with 34 of 38 subs stacked, 6x300s + 32 x 120s (EQMOD crashed doing the 300s subs).
The major difference is a 5mm T spacer between the Baader SCT to T mount unit and the Canon adaptor. And lo, there were round stars! (maybe no quite round enough for you perfecionists!). The remaining mis-shappeness I think is now just guiding jumps and jitters as described.
Thanks to Mick and Chris for the EQMOD Rate setting - not 0.2 use 0.5! Makes calibration of PHD a lot quicker too.
Full size image here (1.8Mb)
Here is the same crop as before:
Wow Dunc - looks tons better - nice one. Bet you are feeling chuffed with that - John. :-)
Great Duncan, I am going to reprocess mine now, as it does not look too good!!!!!!
Duncan,
That's much better!  Those stars have a much better shape now.
That's definitely the best one.  The core is showing more detail and the stars are nice and round.
