8" F4 Astrograph
Started by Rocket Pooch, May 20, 2011, 07:57:42
Right,
After the stepper focuser was completed I now have the carbon tube (10mm thick walls), it's been in the bedroom for a few weeks, on its way from the good old USA is a 3 vane custom curved spider for the seconday.
Flock, Baffles and Ultra Black flat paint here, as well as the holo primary spot....
I just need to decide what to do with the focuser and primary support, the rings already on the way.....
Then I have to start drilling and assembling!
Then it's the QSI upgrade and finder scopes?
Nearly there.
Will there be anything original remaining?  Primary mirror I guess ...
Couple of updates whilst I'm waiting for my custom primary holder!
I found these guys for my electronic focuser pullys http://www.technobotsonline.com/, they have loads of robotics parts.
My secondary holder arrived some time ago, its cool, look below, ignore the fabric in the tube this will come out later.
IMG_1897 by chrissuddell, on Flickr
Has the secondary holder got a wire attached ?
and why ?
If anyone eve orders from Technobots, let me know as I can get you 10% off.
FWIW I've used these people http://www.ondrives.com/index.php
They supplied the coupling I used to connect my focuser to the stepper motor and have an incredible range of bits.
Mick,
The wires are for a secondary heater, you put a + and - on seperate spider legs, cool eh!
It's looking very good Chris!
QuoteThe wires are for a secondary heater, you put a + and - on seperate spider legs, cool eh!
Clever idea, but I think carbon fibre is conductive  :(
You would need to insulate the legs from the tube
Carbon fibre is conductive but I am sure that tube has some kind of coating.
The gelcoat would be an insulator but fixing bolts would be in contact with the carbon unless they were sleeved.
Hi All,
I think you have managed to answer the conductive question yourself :-)
Like the look of that Chris. The secondary heater is a nice touch.  :D
