Fay - Screen Print Problem
Started by JohnP, Mar 23, 2011, 10:19:35
Below is the scree print Fay was trying to upload....
Oh thanks John,,,DOH!!!!!!!
Well as you can see I have a box around the star I want to focus, but it does not show up in the focus box.
The FWMX & Y stay as zero, while big figure in focus. I have contacted AA & QSI & they both say it is to do with each other.
I have to go into Nebulosity, at the moment to focus
Do you have dark frames enabled or disabled?
I guess the focus box is either empty or is picking up the wrong section of whole image.  You can find out which, by pointing your camera at your garden or a picture or a newspaper.  But that still won't tell you who is to blame.
Fay - Exactly what I said before - why don't you test in the daylight rather than wait until imaging....
You have exposure at 0.3 - Is that 1/3 second ?
Fay,
It looks like you initia. exposure was 240 seconds 4 minutes and yet your focus is .3 sec, thats approx 960x shorter exposure, I'm not suprised you can't see anything :-)  Correct me if I'm wrong?
I normally do an exposure of 5 seconds, find a brigh star and then focus at 2 second, remembering there's not a lot of point doing it any quicker because the shutter has to rotate out the way.
Also on AA under options turn on Advanced and you will see you can change the histogram.
I was doing 0.3 secs 2x2, do you think that is the problem? Not long enough focus exposure time?
I will be outside tonight, so will test that
I did test in daylight John. I focused on a plate in the living room & it was ok, it filled the focus box
Chris, usually I do a sub of around 30 secs, so I can see some stars.I did not used to use AA for focusing, that is why I am not used to it, always done it by sight before.
Will have another go tonight & do longer focus sub
dark frame off, Mike
If you're doing 30 secs to see a star, you won't see one at 0.3 sec
It looks like what chris has said is right - The background of the sub shown in your screen print looks quite smooth - so as chris said this is a 4min sub you have then selected a star & only done a .3sec sub so you wont see. You need to loop say 2 or 5 sec subs (background will be a lot noiser I guess) & then pick a star to focus on...
thanks, I will have a go tonight
Fay,
I always use my alignment star for focusing since it is very bright and allows for short exposure times (e.g. 1 sec).
