Author Topic: Binned flats  (Read 2593 times)
Re: Binned flats
« Reply #15 on: Mar 09, 2011, 08:55:13 »
583WS
WS = Weally Slow?
  • Galaxy Class
Re: Binned flats
« Reply #16 on: Mar 09, 2011, 09:16:49 »
Fay, I have the same problem.  The issue is that because the sensor is full frame it needs a mechanical shutter.  The shutters used on these cameras are not focal plane like the Canon so if you need to take flats then they have to be at a low light level to prevent any shadowing on the image and that means longer integration times.
  • Non-OAS
  • Galaxy Class
Re: Binned flats
« Reply #17 on: Mar 09, 2011, 09:24:10 »
Hi Fay,
I'm not really sure what you expecting, the QSI is a completely different camera than the ATIK, the flats and subs sound a little slow, maybe the laptop, but the 2 second focus is the same as mine.  I thought DSLR took a while to download as well and you seem happy with that.
Anyway, did you ask Jim about Nebulocity, he seemed to get on with it really well, no issues focusing etc.
  • Galaxy Class
Re: Binned flats
« Reply #18 on: Mar 09, 2011, 09:24:46 »
sorry that last sentance should have read:
if you need to take flats then they have to be at longer integration times to prevent any shutter shadowing and that means a low light level to prevent saturation.
  • Non-OAS
  • Galaxy Class
Re: Binned flats
« Reply #19 on: Mar 09, 2011, 09:29:18 »
Also, and I forgot to add, the flats should be the same size as the subs.
    • Faysastroimages
Re: Binned flats
« Reply #20 on: Mar 09, 2011, 12:13:20 »
Robert, what do you mean, "that means a low light level"? I am doing then at around 33,000 adu
    • Faysastroimages
Re: Binned flats
« Reply #21 on: Mar 09, 2011, 12:14:49 »
Chris, I am getting the hang of it. At the moment, it is just the slow flat download, that is a bind, everything else is gradually falling into place.
  • Galaxy Class
Re: Binned flats
« Reply #22 on: Mar 09, 2011, 12:30:48 »
I mean that the subs for the flats need to have a longer exposure so whatever you're doing the flats against will need to be dimmer so you reach the same ADU level.  Does that make sense?
Also as I've mentioned in a previous posting you should ideally be using 2/3rds well depth for better s/n so that's 65000 *2/3 = 40,000 (I'd better not get any more technical or the post shifters will move in).  Though that shouldn't matter very much if the optics produce a fairly flat field to start with.
    • Faysastroimages
Re: Binned flats
« Reply #23 on: Mar 09, 2011, 12:38:31 »
Using the QSI with ED80 & flattener, does produce vignetting. With the 7nm ha filter, I had to do 20sec subs to get to 33,000 adu.
Never done that long before, never over 4 sec
  • Non-OAS
  • Galaxy Class
Re: Binned flats
« Reply #24 on: Mar 09, 2011, 12:42:43 »
Fay,
Your not putting a 2" nose piece on the front of the flattener and then onto the scope are you?
    • Faysastroimages
Re: Binned flats
« Reply #25 on: Mar 09, 2011, 12:49:38 »
no, direct connection, I do have to bring it out quite a way for focus
  • Non-OAS
  • Galaxy Class
Re: Binned flats
« Reply #26 on: Mar 09, 2011, 13:11:06 »
Fay,
Look at the picture below, from the back of the reducer to the chip it has to be 55mm, there is 36mm from the front of the QSI to the chip, this means you need 19mm from the back of the reducer to the front of the camera, if you do not have these dimensions right you may get issues, I do not get any Vignetting with mine so I can only assume something is up.
Testing the Telescope Service OAG by chrissuddell, on Flickr
    • Faysastroimages
Re: Binned flats
« Reply #27 on: Mar 09, 2011, 13:46:27 »
I have just received 19mm from Ian. I have to connect it to my other adapter as well, or it does not fit on the flattener. Is that right? Have you got 2 adpators into the camera, to make it 19mm?
Looking at your picture, my drawtube is out another 3 times more than yours!
  • Exile Under Darker Skies
  • R.I.P.
Re: Binned flats
« Reply #28 on: Mar 09, 2011, 14:06:08 »
Chris has the OAG in there as well.
Did Ian suggest the 19mm adapter to fit all your stuff together ?
    • Faysastroimages
Re: Binned flats
« Reply #29 on: Mar 09, 2011, 14:07:42 »
Well Chris said to get the 19mm, but I am wondering if it is a different distance to his.
Chris where are you?
