A Bad Evening!
Started by Fay, Mar 07, 2011, 21:36:07
I am ok with the artifacts now, Chris, it was the cooling bit that was doing it. I saw the figure 9 in that box bottom right & now realise the the was the temp. Astroart does not mention anything about that.
It is only the focus, & framing that is my concern now!!  I will practice in a minute
It might not have been very bright, did you get any numbers in the right side of the box?
The numbers were on zero.
Chris, can you bin flats?
Yes you can, I'm going to have too with mine to complete my image.
Thank God for that, too late for tonight. I was doing flats & they started off at 33,500 adu and by the end, they were 28,800adu. Do you think the light diminishes in the light panel if it is on too long?
looks like they must do!
Ok, I just had a go at focusing & the star was not in the box. There is a big number bottom right, but the other two are zeros.
I will put a post on QSI forum
Fay,
I think this is AstroArt thats the problem not QSI, maybe post there?  or both.
Quote from: Fay
mine takes about 28 secs
I can't believe you waited for a dark, cold, freezing night out in the back garden to try this out.  Why not experiment in daytime in the warmth of your home - both for your own comfort and so as not to waste valuable imaging time.
Hi Mark, i have not stopped experimenting since I got it.  All the other problems were the fact that I had not turned cooling on. Trouble was, I was still in the throes when the first good night came up & I had to go outside with what I knew at the time. And last night was the next good night, so had to go outside again. Learning in the field, so as to speak.
I just have to sort out the focusing & download times. It may have the same sort of size chip as the Canon, but the Canon is immediate in downloading subs. I assumed that QSI would be the same, but not so.
