Author Topic: Tonight, where have the clear skies at 6pm gone?  (Read 4486 times)
    • Faysastroimages
« on: Mar 06, 2011, 19:37:21 »
Well I have setup but still thick cloud. I have covered everything up in case sky clears too late as tomorrow night is supposed to be good.
Not wasting my time, have done 35 bias & now doing 35 dark 300s
Disappointed in the forecast, but I will be ready for tomorrow
    • Carole's images
Re: Tonight, where have the clear skies at 6pm gone?
« Reply #1 on: Mar 06, 2011, 20:01:07 »
I was just about to post something similar.  All the forecasts have said clear all night, even the IR satellites say there should be no cloud.
What's going on!!
« Last Edit: Mar 06, 2011, 22:30:56 by Carole »
    • Faysastroimages
« Reply #2 on: Mar 06, 2011, 20:09:51 »
cracks me up! Why has no one got it right. It will probably clear in an hour or so
  • Galaxy Class
    • smile
« Reply #3 on: Mar 06, 2011, 21:21:21 »
Well its crystal clear down this way, but thats only because im off to work again.
Not too sure what way any clouds are going, so it might be going towards london.
« Reply #4 on: Mar 06, 2011, 22:00:31 »
Quote from: Carole
All the forecasts have said clear all night, even the IR satelittes say there should be no cloud.
The trouble with IR satellites is that when the cloud is the same temperature as the sky below, the clouds are invisible.
    • Faysastroimages
« Reply #5 on: Mar 06, 2011, 22:05:53 »
About time they sussed out a reliable way to give us a proper forecast! :bug:
  • Administrator
  • Galaxy Class
« Reply #6 on: Mar 06, 2011, 22:07:57 »
going outside and looking up, it looks like the cloud might be breaking up.
Pity, I'm far to too tired to get any kit out. It was my son's birthday today and he's run us all ragged...
    • Faysastroimages
« Reply #7 on: Mar 06, 2011, 22:11:12 »
Don't want you getting your kit out, this time of night Ian..............................too late        :parrot:
    • Carole's images
« Reply #8 on: Mar 06, 2011, 22:23:43 »
Well it looked like it was clearing about 40 minutes ago, so I am aligned and on my target, so shall leave it there for the time being, so if the clouds do clear later I'm ready to go.  Meanwhile doing darks.
......and making myself a larger bahtinhov mask while I'm waiting.... fiddly bloomin job that is.
  • Galaxy Class
    • smile
« Reply #9 on: Mar 06, 2011, 22:47:05 »
Quote
as in bigger slats?
or physically larger?
    • Carole's images
« Reply #10 on: Mar 06, 2011, 22:52:08 »
Quote
as in bigger slats?
Both.
I've got a larger telescope so the existing Bahtinov is a bit small (currently got it suspended on bendy wires in the middle of the aperture as a temporary measure).  The larger one has slightly larger slats as well.  One reason why I didn't make one the first time around as they were so small.
I've finished now just got to fix something to it to keep it on the scope and I'm done.  Worn a big blister on my finger doing it.
  • Galaxy Class
    • smile
« Reply #11 on: Mar 07, 2011, 02:01:12 »
Quote
Hammer and nail, or failing that, some glue. ;)
  • Non-OAS
  • Galaxy Class
« Reply #12 on: Mar 07, 2011, 07:44:34 »
was perfect here last night you should have done dsc at blacklands.....
shame i'm off to work in a min..
  • Administrator
  • Galaxy Class
« Reply #13 on: Mar 07, 2011, 09:40:33 »
I think it was too cold too. Anything relying on anything brass to hold it in place would have ended up on the floor last night...
  • Galaxy Class
« Reply #14 on: Mar 07, 2011, 11:46:11 »
The last time that happened, it produced the exact reason why he was run ragged the weekend.  ;)
