[Baa-ebulletin 00544] Observing Alert: Spots on Saturn
Started by Rick, Dec 12, 2010, 11:58:19
BAA electronic bulletin -- http://www.britastro.org/
(c) 2010 British Astronomical Association
On 8 Dec 2010 two spots were recorded on Saturn at the same latitude.
Firstly, a bright spot was recorded close to the central meridian in an image taken at 02:12UT by Sadegh Ghomizadeh in Iran. The provisional position for this spot masured from the image is: latitude 37.5 degrees north (planetographic), longitude (System 3) 248 degrees.
Just over 5 hours later, David Gray in the UK visually recorded a light spot approaching the p. limb. The provisional position for this spot measured from David's drawing is: latitude of 37.5 degrees north,  longitude (System 3) 29 degrees.
Saturn is well placed for observation before dawn and more observations are urgently required to confirm these features.
Mike Foulkes
BAA Saturn Section director.
12 December 2010
