Observatory Design
Started by MarkS, Dec 07, 2010, 05:50:31
I'm thinking through ideas for a possible observatory.
I don't want a dome because it might attract unwanted attention, so I want to disguise the observatory as some kind of shed. In operating mode, ideally I want to see right down to the horizon in the S and down to the horizon in all directions round to the NW and NE.  The north is allowed to be slightly obstructed.
I wondered about something along following lines:
The top half of the side panels (E&W) together with the roof slide back as one unit towards the north.  The North wall (housing the door remains fixed.  The South wall folds down to half height after retraction.
The main problem I see would be ensuring the whole construction has sufficent rigidity.
Does anyone have any other ideas?
Moving two wall sections with the roof would be no less stable than moving one.
If following the design of Robert's, the guide rails for the roll off could be at the height of hand rails which would not look abnormal or attract attention.
The only issue would be the view to the north - a flat (sloped) roof would give more clearance
Dont forget that for an equatorial the telescope is at it's highest point when pointing East or West so the sides may not need to be as low as you think.  You could of course have the whole structure on rails but given sufficient bracing and a light enough roof anything in between would be possible.  there are plenty of examples on the web of observatories with very large rolloff rooves (10' x 12').
Your looking for a shed type of camouflage.
How about somethin along these lines, rather then a RORO shed roof.
Its small, but sort of what you are looking along.
http://my-roll-off-telescope-shed.moonfruit.com/#/open-door/4520353604
Failing that there are loads of ideas on google,
heres an interesting concept.
As well as the roof sliding how about the wall as well.
http://www.alexandersobservatories.com/
The bottom one is what mine looks like (other than being green and rolling to the other side).
Quote from: mickw
On the contrary - there's a risk that without extra bracing, the walls/roof unit could collapse it itself - pancaking.  But extra bracing might collide with the scope ...
I quite like the idea of a complete shed that rolls away to the North - it might end up being the simplest solution.  Trouble is, North is uphill!
QuoteTrouble is, North is uphill!
Does this mean you already have a house in mind?
Quote from: Carole
Potentially, yes, just a couple of miles walk from my all-time favourite imaging place of Tuesnoad.
But this is early days and in the arena of house-moves, nothing is ever certain ...
QuoteOn the contrary - there's a risk that without extra bracing, the walls/roof unit could collapse it itself - pancaking.  But extra bracing might collide with the scope ...
I had assumed the "other wall" would be braced also.
The bracing should only hit the telescope if it is leaning against the wall
Quote from: MarkS on Dec 07, 2010, 21:36:28
Quote from: Carole
will there be mud???
Quote from: Ian
Hopefully not!
Quote from: MarkS on Dec 08, 2010, 06:18:58
Quote from: Ian
Hopefully not!
will there be explosives???
More importantly, will there be room for a small DSC group?
At £20 a head, I'd reckon yes  ;)
Quote from: Ian
will there be sheep?
