Eclipse Pics
Started by Mike, May 05, 2004, 06:25:00
Here are some pics I managed to get at the field through the clouds.
300mm @ 3 secs
Moon and passing aircraft - 300mm @ 3 secs
The ghosts of Tripes farm - 70mm @ 10 secs
(Note these images are compressed and reduced in size from the originals)
_________________
"Without question, the greatest invention in the history of mankind is beer. Oh, I grant you that the wheel was also a fine invention, but the wheel does not go nearly as well with pizza."  [/i]
[ This Message was edited by: Mike on 2004-05-04 22:26 ]
Nigel
Well worth the effort, typically weather was completely clear when i got back to Petts Wood, by then the eclipse was about 80%, but still impressive.
Sheesh! That last one shows how much stray light we get up near the top of the field!
Exactly - I took 263 more pics later from the upstairs window when it cleared again. I shall pick out the best ones and post them up. I should be able to make an animated gif of the shadow moving across the moon as I took images over about an hour.
That was a realy dark eclipse last night.
