Animation of Jupiter with Ganymede 3 September
Started by MarkS, Sep 04, 2010, 16:19:02
I took 6 hours of video at 5 fps last night from 23:00 BST to 5:00BST - 45Gbytes in total.
Philips SPC900 webcam on Celestron C11 with x2 Barlow.
This animation is 24 frames and covers the first 80minutes of that 6 hours.  Each animation frame was created from 1000 original frames stacked in Registax.  I took a quick a dirty approach, stacking the frames in 10's first, which means that the final animation frames are not as sharp and detailed as they could have been - the seeing was not so good either.
Warning - this is 1.7Mbytes
http://www.markshelley.co.uk/Astronomy/2010/jupanimation3sep2010.gif
Unfortunately, as Jupiter climbed into the sky, it became brighter and the core began to burn out, which is very annoying but I'll know better for next time!
QuoteWarning - this is 1.7Mbytes
Is that supposed to be big?
Had it said 17M or 170M then that would have probably needed a warning, but not 1.7 Meg.
Excellent Animation though.
Very nice work on Jupiter in the last couple of days Mark.
All with a webcam and none of your really fancy kit.
With a little/lot of effort, anyone could do it.  Thanks for demonstrating that  :)
Mick
Quote from: mickw
That's right Mick - the trick is to choose nights with good seeing - then a humble webcam can produce fantastic results for planetary/lunar imaging - the only limitation is the scope aperture.
I'm working on a complete re-processing of last night's data.  Version 2 of the animation will be much better ...
PhilB
Beautiful animation, Mark. I bet the  tweaked version will be spectacular.
I know it's a lot of work, but how much of the full sequence are you eventually hoping to animate?
I'm up to 3 hours of animation now in my complete re-process from scratch - some of these later frames have excellent seeing and would make worthwhile images in their own right.
That's amazing. Well done Mark, you must have incredible patience.
Quote from: The Thing
Some would call it obsessiveness!
I've got a 6 hour 45Gbyte AVI file recorded by VirtualDub onto an external hard drive (no free disk space on my laptop).
Using VirtualDub I've now chopped this into segments of 1000 frames (200 sec).
Each segment is now being processed in Registax.
Then each frame will be combined into a movie.
Actually, I think it might even be called insanity ...
Shame Registax can't be set to do the chopping up. Maybe a note to the authors?
