First tests with Nikon D70
Started by Mike, Apr 21, 2004, 07:30:00
OK I've got it - seems pretty good. Will use it from now on. Thanks.
Two more. These weren't driven so there is a slight star trailing on them :-
Head of Hydra and Beehive Cluster M44
For full size jpeg click here - http://homepage.ntlworld.com/astro-man/HydraandBeehiveLarge.jpg
Saturn, Mars and Venus
Nice one mate,
What magnitude are you getting to in 20 secs?
Looking at the RAW file and comparing it with stars in Starry Night Pro I got down to 9.78 (On the Hydra and M44 image)
[ This Message was edited by: Mike on 2004-04-22 07:43 ]
That's good going with such a wide field.
What type of mount are the lenses?
Nikon F Mount. I will do some images facing south next time as that is much darker and see what mag I can get down to. I will also try out the 300mm lens once I have aligned the ETX properly to see how that fares.
Managed to finally get a T2 mount for the Nikon and the ETX came with some adaptor rings and tubes that should fit. I shall have a play at the next opportunity.
Thought i'd put this one up i did today, simply because it was a pretty picture :-
[ This Message was edited by: Mike on 2004-04-23 23:51 ]
